i have 1985 325e the car ran good for a few months then one night kinda gave it a good beat. it ran fine on the way home next morning go to start wont turn over. i need help bad
THE CAR CRANKS BUT WONT TURN OVER.
i tried everything changed the crank sensors out tried a different ecu got brand new distributor cap and rotor. new battery,new coil tried different main relay fuel pump relay. changed out the ignition switch still nothing then started checking for power. TURNS OUT NOT GETTING ANYTHING TO THE COIL. what do you guys think can be causing this problem
all help is appreciated thank you.
