injector leaking
  • timninja
    • Feb 2011
    • 302
    injector leaking
    Hey is there any write ups with images on m20 fuel injector replacements?
    I'm a mobile user so the search option isn't working,and Google is showing me m50 write ups,
    Thanks for your time.
  • MonkeyMadness
    • 3251
    dude without being a DICK and telling you to "search"
    It's easy, pull valve cover. unplug injectors from harness.
    remove the 4 10mm bolts, remove fuel lines, unplug temp looking plug by thermo
    Roll injectors towards head and slip out from between head and intake..
    • timninja
      • Feb 2011
      • 302
      Sweet thank you!^
      • MonkeyMadness
        • 3251
        Post your progress...
        If you need help hit me up..
        Are you going to rebuild/clean your injectors?
