Look like its time for new cap & rotor?
  • Mab1957
    • 61
    I bought this '92 325ic in 2010 with 120k on it. Now has 125k. Is it time for new distributor cap and rotor?
    I am changing the water pump and timing belt.
    Thanks for the tech help on that job from this forum! :D
    Matt
    McLean, VA
  • dchun
    • 67
    yes change it.
    I just bought a 325e with 116K and the cap and rotor looked like it was never changed.
    runs much better with the new parts!
    • AndrewBird
      The Mad Scientist
      • 11898
      You can just clean the contacts up with a bit of sandpaper or a wire brush, but replacing them is also a good idea. You can only clean them so many times before the spacing between the contacts get too far and causes problems.
      • SpecM
        • Oct 2005
        • 4531
        might as well replace them, they are clearly worn and you already have them off
        1989 cirrisblau-metallic 325i
        • Mab1957
          • 61
          Thanks! I ordered replacements from Blunttech. I'll scuff these off and put them in the M20 emergency kit with the old hoses and belts.
          Matt
          McLean, VA
          • Madhatter
            • Oct 2004
            • 966
            mine was pretty bad.
            :giggle:
            Just a little project im working on
            - http://www.lse30.com -
            • mikeb23ft
              • 390
              Mine were shot too. Replaced them yesterday and the car runs much better now.
