Spark plugs are a pain to remove
  • dandan1
    • 111
    So I'm going thru my rounds of maintenance items including replacing the spark plugs. I'm not sure what the previous owner did but for the life of me I couldn't even get them to budge a tiny bit. I even tried a break bar but stopped because I was using too much force and was afraid something might snap so I stopped.
    I went down the line and tried every plug and each one of them were as stiff as a rock.
    And yes I'm using the correct spark plug socket. Any advice?
    Ping me for photo sessions: ISOlution|Photography
  • LJ851
    • 7919
    Work out?
    You could try to spray some penetrating oil down the spark plug openings, but i'm not sure it would get past the spark plug crush washers.
    Good luck
    Lorin
    The M30 is God's engine.
    • dandan1
      • 111
      Haha, I'm not small by any means and I just didn't want to over muscle anything. The breaker bar that I was using was about 2ft long so I know I had enough leverage, but the damn plugs just wouldn't break loose.
      I thought about spraying some PB Blaster in there, but wasn't too comfortable with the idea of getting that kind of liquid stuck in the hole.
      I'll have another go at it again tonight after dinner and see what happens.
      Ggrrr...
      • devon.818
        • Feb 2011
        • 2937
        dont be like the guy who broke one off in his cylinder head, he kept asking if he could just "drill it out" without removing the head....good luck lol
        • acolella76
          • 2950
          I had the bright idea to let a shop diagnose something wrong with my car one time. Three days later they called me and told me it was the spark plugs so they charged me $115 for the plugs and installed them. Tried to get them out a week later to run a compression test and they gorilla torqued the shit out of them it seemed. They came out just fine eventually... when I pulled the head.
          -Alex
          • dandan1
            • 111
            Ugh great. Why do people need to torque these down with titanic force, even the box says 21ft/lbs.
            According to my previous records the plugs were changed at a local BMW dealership so hopefully they knew what they were doing.
            • paperplane94
              • Jul 2011
              • 420
              More breaker bar...
              • paperplane94
                • Jul 2011
                • 420
                Also go buy a threadchaser before you find out they are stripped.
                • dandan1
                  • 111
                  Originally posted by paperplane94
                  More breaker bar...
                  That's exactly what I did. Used a different bar to use and carefully loosen them. Wasn't so bad once I managed to get the first one done. Took my time and everything went smoothly.
                  The ones in the car originally were Bosch Platinum Super Plus and the new ones are NGK ZGR5As. Car is running beautifully (not that it wasn't before) along with new distributor cap and rotor which was also done today.
                  Thankfully I didn't need to go there.
                  Thanks for the help guys.
                  • Hey_You
                    • Nov 2009
                    • 963
                    Hope you put some Anti-Seize on the new plugs
                    85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
                    • dandan1
                      • 111
                      Of course, I do things the right way around here. Lubed up the plugs on both ends.
                      Next up, fuel filter, spark plug wires, ICV cleaning, ellipsoids, black door panels, injectors, chip, better seats, Z3 short shifter, suspension, wheels... I should start a maintenance/project thread...
                        • 37829
                        Most likely they weren't overtorqued but were just seized. Whoever did it last time skipped the anti-seize. :)
                        FYI though, you're not going to hurt anything is PB Blaster gets in the spark plug hole.
                        Classic BMW Specialists
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • dandan1
                          • 111
                          That's what I was thinking too, the lack of anti-seize caused the difficulty. But not anymore since I did it the right way this time.
                          Also, good to know about the PB Blaster!
                          • Madhatter
                            • Oct 2004
                            • 966
                            Its amazing the difference it makes.
                            Just a little project im working on
                            - http://www.lse30.com -
