Hi all,
I'm having a hesitation issue with my 2.7 m20, auto. When driving, sometimes it just doesn't want to move. It feels like you're in a high gear at very low rpm. I'll floor it and it will just play dead and slowly accelerate. You can hear the engine struggling. At some point around 3k, it kicks in and shoots off like normal.
Some more information:
- at cold startup, the idle bounces around for about 15-20 seconds (800-1400rpm) and then settles normally
- this issue has really pronounced itself after seafoaming the engine through the fuel pressure regulator vacuum line - not sure if the two are connected
- the car get's TERRIBLE gas mileage (it did before this issue too) - around 210 miles to a 55L tank, mostly highway
- happens when the car is full (2 or more people) more often than when I'm by myself
- the external fuel pump hums, but did so before - I will check to make sure the in-tank pump is still working by unplugging it and seeing if the external reacts
- I changed the plugs to newly gapped NGKs, no difference
- this is a Motronic 1.0 car, so there are no CEL codes to check
As always, your help is appreciated.
Thanks
Thanks
