Recently added a Miller MAF/WAR Chip and having cold idling issues, but other than that and the CEL it runs PERFECTLY.
CEL and Cold Idle Problems:
So I tested the MAF and its getting proper readings and voltage, so I know it is not the problem, the car runs excellent (better than ever) when warm, during cold idle tho, it wants to idle at 5-600 rpm's poorly. When warm, idles perfectly around 750-800. CEL is on and throwing the 1215 Code...
"Code 1215 - Indicates problem relating to Air / Mass Flow Meter - AFM or MAF depending on your e30 model. Causes could be cable wire damage, short circuit in the unit, or air / vacuum leak (check air intake hose - big L-shaped one)"
Funny thing was last night I drove my car HARD on Hwy 9, and the CEL shut off. The car was running awesome, before and after the CEL was on (once warmed up). But today when i started my car CEL popped back on and poor cold idle remained until the O2 sensor kicked in.
Brody @ Miller was helping me diagnose what's going on, and we haven't ruled out the TPS completely, and he told me the ICV should be pretty loose. He says you should be able to hear it open/close by shaking the ICV as you would a doorknob, and I think mines a little sticky because I have to give it kind of a harder shake to hear it. So I blasted the hell out of the ICV with some carb cleaner for a second time, It looks spic n span in there, but it still doesn't shake as loose as I think it should. Can someone confirm this?
Any ideas would be greatly appreciated. Although my car runs better than ever other than the cold idle (2-3 mins) and throws the 1215 CEL code, I want these 2 problems gone.
P.S.
The Miller MAF/WAR is a must for m20's I think...and I have a feeling this problem has nothing to do with the MAF install, but may be just a little more evident than before, because before the Miller MAF/WAR, my idle was crap as well, but always. Now its at least great when its warm, only only crap when the engines cold.
P.S.
