Oil Leak from B*tch Tube
  • CabbE30
    • Aug 2009
    • 2358
    The bottom part of my bitch tube is leaking mad amounts of oil. Whats the most time-effective & cost-effective method to fix this. I know I could take off the intake manifold to fix it but is there any other way? I'm assuming I have to replace the O-rings.
  • bmwstephen
    • 2463
    you can compress the spring with a zip tie, then lift the tube up with the washer to expose the seal. then clean the area real good and dab some high temp silicon on it and let it sit overnight.
    • paperplane94
      • Jul 2011
      • 420
      nothin fancy
      Its cake!
      Just remove the Manifold.
      Remove the tube,
      Replace the O-rings
      Use zip ties to compress the spring
      put the mani back on, replace the gaskets if you can
      cut the zip ties to deploy the spring
      Torque away!
      The bentley or haynes helps
      • BrassDrummer
        • Feb 2012
        • 68
        Man... Zip Ties... How did I not think of that. I just rebuilt my first M20, and that tube was one of the biggest pain in the asses on that entire rebuild.
        • firefirefire90
          • 163
          bitch tube?
          • Keith M
            • 2338
            Breather tube from the block to the intake manifold.
            • paperplane94
              • Jul 2011
              • 420
              For all those people who find it more convenient to bother you with their question rather than to Google it for themselves.
              I just found a nice thread using my own link above :)
                • 37832
                I'm sick of people saying this tube is difficult! IT'S NOT.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • The Humjet
                  • Jun 2010
                  • 528
                  I know what are these guys on about. I didn't even use cable ties. Off by hand in 2 minutes.
                  • CabbE30
                    • Aug 2009
                    • 2358
                    Thanks guys. Ill fix this today.
                    • CabbE30
                      • Aug 2009
                      • 2358
                      Looks like my washer is MIA. Im going to have to order the washer, the o-rings and the gasket for the intake manifold.
                      • acolella76
                        • 2950
                        You should just do what the PO of my engine did.
                        -Alex
                        • TimKninja
                          • 2131
                          Yea you NEED that washer or itll leak like a mofo.
                          And no you cant find it at Home depot or lowes.
                          1985 325e M50TU(Sold)
                          1991 318is Slicktop (Sold)
                          1990 325is Brilliantrot S50/5 Lug Swapped.
                          1992 525i Manual shitbox Winter Beater
