Had a problem with it not starting...changed in tank pump and it starts but only runs for about 15 mins and then won't start till next morning and does the same thing...fuel filter also changed...I'm at wits end...any ideas?
85 e30 won't stay on running
Check the plugs after it stalls? if they are wet, its flooding out. Would explain the no start until it sits for a while. If so maybe leaky injectors or bad FPR. -
what do you mean by check the plugs? sorry not to mechanically savy
EDit:ok spark plugs...will check and respond tommLast edited by Ransom; 02-22-2012, 02:23 PM.Comment
