525i m20 driveshaft confusion
  • alfie
    • Aug 2011
    • 36
    hey guys back again. i swapped in a 525i m20 motor into my e30 and thought that i had everything figured out. turns out that for the most part i did untill i ran into an issue mounting the e30 drive shaft onto the new motor. i noticed that the flex dics are different sizes. i also noticed that the flex dics for the new motor was mounted diffrently then how it was on the stock e30 motor.
    i am fairly new to e30's so maybe this is something that is a common and well known problem but i am not sure if to get a different drive shaft or to try and rig the one i have somehow ?
    as always thanks in advanced for any input..
    luis...
    The best fix for this is to swap the transmission output flange to the one that the car would normally have.
