I just purchased a 1987 325e for $650. Right off the bat the car jerks ans stutters in every gear at low RPM it almost feels like its a fuel cut. At higher RPM's there is no issues. I look it to my local euro shop to have them go over it. I had them do a smoke test and adjust the valves do see if this help it, and I did't. Yesterday I changed the oil, filter and put some Restore in with the oil as well as added some fuel treatment to the fuel tank. Also I replaced the spark plugs and check the injectors. Again low rpm or if the engine is cold....jerk and stutter but at High RPM fine. Any thoughts?
Low RPM Studdering
I have the same issue! I replaced coil, wires, plugs, dist cap, rotor, injectors, timing belt, water pump, crank position sensor, coolant temp sensor, fuel pump, fuel filter, most air hoses, intake boot, valve cover gasket and valve adjustments, o2 sensor, cleaned afm and icv.
Three oddities I've noticed. If I unplug the AFM the car runs the same as it does without it besides the CEL being on. A local mechanic says he thinks that may be the issue as these e30s use an "average" if its not getting a correct signal from the AFM. Is there a better way to test this than buying a new/used one and swapping? Rarely, if I'm at a stop light, the CEL will go on until I hit the gas which immediately knocks it off. After this happened I decided to do the stomp test, which worked once in about a hundred tries. I did it every time I got to my destination until it worked. Code 1222 Lambda control 1 came out.
Given all of this information where should I start? Do all of these puzzle pieces come together pointing towards one thing? Analytically I'm thinking the tps might be the issue?
Originally posted by wcipolli View PostI have the same issue! I replaced coil, wires, plugs, dist cap, rotor, injectors, timing belt, water pump, crank position sensor, coolant temp sensor, fuel pump, fuel filter, most air hoses, intake boot, valve cover gasket and valve adjustments, o2 sensor, cleaned afm and icv.
Given all of this information where should I start? Do all of these puzzle pieces come together pointing towards one thing? Analytically I'm thinking the tps might be the issue?The car makes it possible, but the driver makes it happen.
