I've got an 87 325is that I can't figure out where a small oil leak is coming from. I replaced the oil pan as soon as I bought the car and that cleaned up a lot of the problem. Besides the valve cover where else could a gasket be failing or some part of the oil system leak?
Oil leaks
Check your oil pressure sensor on the driver pass side. That's a usual culprit.Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
Place to cause oil to be on the exhaust side of the engine are the valve cover gaskets, cam seal, main seal, oil plan gasket, oil filter and/adapter, oil pressure switch, or head gasket. On the intake side the list includes intermediate shaft seal, main seal, drips from the throttle body, oil return tube, power steering system, oil plan gasket, distributor boss plug.
To find an oil leak you can add UV dye to the oil and use a UV light to look for the first sign of leakage. Or throughly clean the engine and watch for the first sign of oil.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
So next step after that....what's everyone's favorite way to clean up some crusty ass oil from the engine bay?Comment
