More Starting Woes
  • EyExR
    • Jan 2011
    • 959
    More Starting Woes
    Strange story. I'm doing a compression test on my iX and when I crank the engine the car seems to slowly die and I can smell burning coming from the distributor. Then it wouldn't get enough juice to turn it over at all. So I had to jump the car to finish the last cylinder.
    I put my plugs back in, reconnect my fuel relay and it starts right up. So I take it for a spin around the neighborhood. All of a sudden I'm not getting any power at all so I pull over.
    I try to fiddle with the plugs, reconnect the fuel relay but it would just crank and not start. Now I smell burning from the engine/tranny area (is this where the starter is located?) and then the car would not crank at all.
    I ran home, got my other car to give it a jump but I get nothing. Dead. No cranking at all. All my dash lights are on but it won't crank.
    Any suggestions on what might be going on here?
    My 325iX DIY Threads:
    Front Wheel Bearing Replacement
    325iX Rear Subframe Bushings and MUCH more w/pics!
    325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
  • kanada
    • Mar 2012
    • 6
    Sounds like starter problem.
    Starter is made from 2 parts: electric motor to turn the engine and electromagnet aka solenoid to engage the starter gear to flywheel.
    So listen to what is going on when you turn the key.
    - you hear a loud click - that is solenoid pushing gears together.
    - you hear a click but engine is not turning over
    - A . your engine is hydro locked - can you turn it over with a wrench? then it is case B.
    - B . burned up starter motor.
    - you do not hear a clic, but hear starter motor turning - bad solenoid.
    - you hear nothing at all - look for blown fuse.
    assuming strong battery.
    KaNaDa
    • EyExR
      • Jan 2011
      • 959
      What would cause a burning smell at the distributor, then the starter?
      Thanks kanada!
      • kanada
        • Mar 2012
        • 6
        Burning electrical whire insulation. If starter shorted out the wires will heat up and eventualy melt if voltage is flowing.....
