Fan clutch help!!!!
    Fan clutch help!!!!
    I need help asap! The fan clutch wont come loose, tried whacking the wrench with a mallet and all it does is spin the pulley tried wedging the screwdriver in there too no go
    Anyone else able to help me?
    SO MUCH MORE TO DO!!
    IG: ohthejosh
    LEGIT CHECK ME BRUH
    BUYER FEEDBACK THREAD
    try this ? GL remember it's left hand thread !
    My CA legal M60 swap
    The happening in our garage
      ^thats what i did worked like a charm
        Im not able to do that because i dont have metric open wrenches. I use a pry bar to lock it in place and im whacking it with a mallet but now im starting to strip the nut. Left handed nut means i have to turn the nut to the right to loosen it and its not budging
        IG: ohthejosh
        LEGIT CHECK ME BRUH
          How big of a hammer are you using. In my experience a 4lb or larger gets it done every time, but you must use the correct sized wrench.
            buy or borrow the fan clutch wrench set. it comes with the tool to hold the pully. i got mine on ebay for 38 bucks for the set. just search bmw fan clutch wrench.
              Im using the 32mm wrench and a rubber mallet
              Right now im willing to just buy that.
              IG: ohthejosh
              LEGIT CHECK ME BRUH
                The rubber mallet is the problem. To break the nut free you need a sharp powerful impact. A rubber mallet or a light hammer can't do that.
                  Okay, i just ordered the pulley holder from ebay so when comes in ill attack that POS fan clutch. Thanks jlevie appreciate the help!
                  IG: ohthejosh
                  LEGIT CHECK ME BRUH
                    Rubber mallet? That was definitely your problem. And I don't know how you got a 32" closed end wrench down there with the radiator and everything still in. Its a car, it's not a woman. Beat the shit out of that fan clutch nut. Angle your wrench slightly towards the drivers side, and hit it as hard as you can with the hammer. (Leave your drive belts on or this will not work) It will spin free. May take a couple tries if you've never done it.
                      I have a 32 mm open end wrench I dont have the 10mm or 8mm for the bolts on the pulley to put the suggested method above on. I am getting the pulley holder in this friday or so and Ill continue from there
                      IG: ohthejosh
                      LEGIT CHECK ME BRUH
