87is M20 to 88is M20
  • MattAvino
    • Jan 2011
    • 2147
    I'm switching the M20 in my 87 325is to an M20 from my 88 325is. What are some details that I might overlook when swapping to the 88 motor? Small differences?
    Thanks.
    This motor:
    Into this car:
    E30 buildy things
    http://www.r3vlimited.com/board/showthread.php?t=195286
  • IRON-E
    • 16548
    Really?
    @IRON-E30 aka Edwin:D
    • MrNatural
      • Apr 2008
      • 237
      Computer for one...
      • MattAvino
        • Jan 2011
        • 2147
        Originally posted by MrNatural
        Computer for one...
        Well yes. But, i'm asking if there is something small that I may over look, especially when wiring up.
        E30 buildy things
        • MattAvino
          • Jan 2011
          • 2147
          Originally posted by IRON-E
          Really?
          Thanks for the help.
          E30 buildy things
            The engine harness used on the 87 & 88 are different. There will be no problems if you use the harness from the 88 engine.
            • MattAvino
              • Jan 2011
              • 2147
              Ok. I will be switching the harness's so no problem there.
              E30 buildy things
              • TurboJake
                • 3780
                The cooling system might be different.
                Other than that though. Nothing really.
                Leave Me Transaction Feedback
                • MattAvino
                  • Jan 2011
                  • 2147
                  Ok, thanks. I foresaw some wiring issues with late/early model differences.
                  E30 buildy things
                    • 37832
                    Use the car's harness and there will be no wiring issues.
                    As mentioned though, the 87 and 88 use different cooling systems. You'll either need to convert the engine to the early cooling system or the car to the late system. Both aren't too difficult.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • MattAvino
                      • Jan 2011
                      • 2147
                      Ok thanks. I think I will opt to convert the early car to the late cooling system, after a quick read through the Cooling System section of the Bentley, the only mention of differences from 87 to 88 were clips in the process of radiator removal. But i will take a good look at both cars, i'm sure I can figure it out.
                      E30 buildy things
                        • 37832
                        No, all of the hoses are different, the radiators are different, the water pumps are different, and the late model has a coolant tube that the early model doesn't have.
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • e30trooper
                          • 11576
                          o2 sensors are different.
                          • MattAvino
                            • Jan 2011
                            • 2147
                            Ok, thought so. I will be swapping everything anyways.
                            E30 buildy things
                            • MattAvino
                              • Jan 2011
                              • 2147
                              That will be swapped with harness
                              E30 buildy things
