Hey all, I have a 1990 325is with 150,000 miles on it. The car runs like a champ. I changed the oil last fall just before storing it for the winter. I ran the car several times in my garage over the winter. About a month ago I discovered a big oil leak coming from between the head and the block between the #3 and #4 cylinders. So I figured that the head gasket has let go and needed to be replaced. I did a compression check prior to tearing it apart and all cylinders were between 160 and 165.
I pulled the engine and changed out all the old seals and gaskets to resolve some old oil seepage issues. I used Victor Reinz seals and head gasket and new head bolts. I torqued the head back down as per the Bently Manual 1st stage 22 ft lbs second stage torque 90 degrees followed by the third stage being another 90 degrees. All went well and the engine went back in. I have since put 250 miles on it and everything was fine no leaks.
The other day I was checking for any leaks and discovered a new oil leak coming from between the head and the cylinder block at the very rear of the engine at the #6 cylinder on the passengers side. New leak at a different location form the original problem. Not too happy at this point!!!
When I installed the head gasket I didn't coat the gasket with any sealant as I have seen some guys do. The car has never been overheated in its life, so I didn't check the head for any warpage, figured it was ok. Kicking myself in the ass at this point!!!
Is there anything i can do to stop this leak i.e. oil additive, or am I going to have to pull the head again and change the head gasket? If it comes to that I will be checking the head for warpage.
There is no coolant in the oil and no loss of coolant thus far.
