engine pull help
  • Chaz
    • Jul 2011
    • 432
    engine pull help
    Trying to remove an engine from my 87 chassis. It is an auto. The Bently manual says nothing about revoming the tranny or disconecting the driveshaft. Right now I need to know the size of the oil cooler bolts because I can't get them out. My 22mm isn't big enough.
    Ideas.
  • 89 e30
    • 249
    You can count right? If 22 isn't big enough you try a 23 than 24....
    BIMMER für IMMER
    • Mikey J
      • Dec 2008
      • 28
      I have a 90 325is that I just finished pulling and my oil cooler lines had a 27 mm nut on them. I seperated the manual tranny prior to pulling but installed it back with both together.
      • ak-
        • 12422
        I dunno man, that's kind of hard.
        1991 325iS turbo
        • Chruby99
          • May 2011
          • 262
          Pull it out together
          • 5Toes
            • 9836
            Ever heard of a monkey wrench?? Worked fine for me
            • Chaz
              • Jul 2011
              • 432
              Yea, well was just stuck. PB blasted it.
              Did you pull the engine out from beneath the car chruby?
                • 37834
                ^ Considering the car is right above the engine with no subframe, I'd say yes he did.
                Grover Beach, California
                BimmerHeads.com
                • cheapshot
                  • 451
                  Easiest way to do it.
                  • Chruby99
                    • May 2011
                    • 262
                    Bought a pallet jack, a pallet, and an extra set of jack stands. Took me about half a day by myself. I am sure it could be done faster. But I took my time.
