M20 ECU Coolant sensor weird idle.
    My car idles low when cold and high when hot. I was curious if the coolant temp sensor could cause this. My multi meter is missing to check the ohm load. Anyone have any ideas?
    I have had the car smoke checked and fixed the bitch tube o-rings.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    Hard to tell without a multimeter. IT could be something else like the FPR.
      The FPR is new and vacuum line fresh
