While doing a valve adjustment with a buddy we came across the #4 and #5 exhaust valves not wanting to adjust to spec. To remedy this I went ahead and ordered 12 new eccentrics/bolts/nuts and readjusted the valves according upon their arrival. Unfortunately this still kept #4 slightly on the loose side and #5 is not making contact at all even with a brand new eccentric. The original eccentric had a visible flat spot and pitting.
Through some searching I've read that lash caps or oversized eccentrics are both possible solutions here. Is one inherently better than the other in the short or long term? I assume that either of these is essentially putting a band aid on a larger problem but I am not prepared to pull the head as this is a daily driver and I'm a college student entering grad school.
Would a compression or leak down test tell me how severe of a problem I'm working with?
Eccentrics I now have experience with but if lash caps are the preferred solution, how are they installed?
For background the car has experienced some bogging issues. I think it is fuel related as it was gone for 4 months after a fuel pump change but it's come back recently. Regardless I would like to eliminate this valve issue before further diagnosing that specific problem.
Thanks guys.
Thanks guys.
