RPM dependent whine, any advise?
  • ME30W
    • Feb 2012
    • 811
    I have an automatic 89 325i. Recently I've been hearing a sight whine that becomes higher pitched as RPMs increase. It's usually drowned out by the engine noise, but at higher RPMs it becomes more audible.
    My first thought was the water pump, but it only has about ~7,000 miles on it
    Everything else with the car has been completely normal, so I'm not quite sure how to go about diagnosing the problem.
    Any advise or help would be greatly appreciated. This might be a long shot, but if anyone who knows these cars well lives in NYC and wouldn't mind lending a helping hand I would certainly make it worth their while.
    I like cats.
  • IRON-E
    • 16548
    Sounds like the t-belt tensioner, but you can always visit Guten Parts Service in Jersey, for a full rundown of the mechanicals.
    Good luck
    @IRON-E30 aka Edwin:D
    • e30Rooster
      • Jan 2010
      • 958
      Power steering....?
      Sent from my C771 using Tapatalk 2
        Assuming the whine is audible when the car is stationary and being rev'd, the belt driven parts can be eliminated as a cause by removing them. With the engine cold, no harm will come by running the engine briefly with the water pump belt off. If the noise isn't coming from one of the belt driven parts, the timing belt tensioner pulley is the next most likely cause. After that it could be from the transmission.
        • ME30W
          • Feb 2012
          • 811
          I don't seem to hear anything when the car is in neutral and I rev it. I'd love to take it to Guten for a look-over, but I called them earlier in the month and was told they have no open appointments until the middle of the summer!
          I like cats.
          • dnguyen1963
            • Nov 2011
            • 2651
            Don't forget to check your alternator. Degenerating alternator can make whining noise.
            • ME30W
              • Feb 2012
              • 811
              I just took a quick drive to listen a little closer to the sound, and it seems that it is more of a hum, kind of like an electric motor noise, that gets higher pitched as RPMs increase.
              Would this then exclude the timing belt tensioner? I'm thinking its the alternator now, but maybe someone can help clarify the situation for me
              I like cats.
              • slammin.e28
                שמע ישראל
                • 12054
                It's not coming from your speakers is it?
                You heard it outside of the car?
                • ME30W
                  • Feb 2012
                  • 811
                  definitely not coming through the speakers, I can hear it inside the cabin while driving
                  I like cats.
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    Use a long screw driver (if you do not have a stethoscope) and place it on the alternator housing and other suspected locations. Listen to it with a friend revving the engine. You can isolate the sound better.
                    • ME30W
                      • Feb 2012
                      • 811
                      Thanks! I'm planning on getting that done tonight, other than the waterpump, and alternator is there anywhere else that I should pay close attention to?
                      I like cats.
                      • dnguyen1963
                        • Nov 2011
                        • 2651
                        Timing belt area...listen for the tensioner.
                        • hamilton325i
                          • Sep 2011
                          • 83
                          I would try to get an ear on anything that has a crank driven pulley if it were me. You can also quickly rule out individual belts by giving each one a small burst of brake clean and see if the noise goes away.
