random no power to ecu with MSII??????
  • der affe
    Technical
    • Dec 2005
    • 8452
    a month ago i started having a problem with this........ turn on the key, dash lights up, no fuel pump priming noise, crank the starter, no fire.
    at first i tried to blame the MSII, but it turns out that it was not getting power to turn on the ecu so it could turn on the fuel pump relay.
    i took a shot and replaced the ignition switch, because
    A. it was the orginal one in the car with close to 300,000 KM on it.
    B. it had an after market alarm at one time in it's life, i had removed all the left over relay and scotch taps, but it looked pretty bad after all the scotch taps were gone.
    well the new ignition switch solved the problem for about a month, until last night, without warning, BAM, same issue again.
    the fuel pump randomly clicks like it is trying to prime (with the key in the ON position), but i am getting no light on the MSII at the box meaning i am not getting power to it.
    i checked the wiring and grounds under the dash and steering colum, they all seem to be fine. i was thinking that there was maybe a wire or ground issue in there that i "fixed" by moving the wires around to install the new ign switch and it has "unfixed" itself.
    i have a handfull of fuel pump and o2 relays that i have swapped in as well as an extra known good main relay that is almost new. still nothing.
    the bently was not too great for the wiring on this so i has a friend pull up diagrams from mitchell on line. much better!
    from the looks of it, power goes through the ignition switch, then to the main relay, to the ecu, then the ecu triggers the fuel pump relay and it primes.
    i think it is a grounding issue because of the way the fuel pump relay is clicking away, but i can't find a bad ground. is there another ground just for the ECU itself? if so where is it hidden?
    any other ideas for this issue????????
  • der affe
    Technical
    • Dec 2005
    • 8452
    i can trigger the fuel pump relay with my power probe, but the main (white relay keeps randomly clicking and no power to the ecu.
    Can anyone tell me what the pins are supposed to be with the key on and off for the main relay?
    unless I am missing it somewhere in the bentley, I can't seem to find it.
    • der affe
      Technical
      • Dec 2005
      • 8452
      With the ignition switch on, #30 & #88 are +, #85 is - & #87 in the center is also - BUT I will not set off the chime on my power probe, it just lights up the neg light.
      • e30leigh
        • Mar 2012
        • 481
        sounds like you have a short to ground. i wouldnt be looking for a bad earth id be looking for shorts.
        if you try get wds wiring diagrams. im not too sure if they can be down loaded. but anything is possible. its extremely indepth and very accurate. alittle hard to use as there is just so much to navigate. but once you get your head around it, its the best wiring diagram system available for bmw's
        • der affe
          Technical
          • Dec 2005
          • 8452
          I hope it isn't a short! The engine harness is new since the MSII install and was in super nice shape.
          My next thing is to do a continuity test on the engine harness tomarrow.
          I wish I could find out the deal on the main relay though, it would save me some extra work or at least point me in a direction.
            In the stock configuration, the main relay is controlled by the DME. When the START signal from the ignition switch is present at the DME the main relay will be activated. I don't know if and MS works the same. Another possible problem would be a bad fusible link.
            • whodwho
              • Jun 2008
              • 1547
              At the ECU
              3 - ground to fuel pump
              18 - steady power
              19 - DME ground
              27 - power from ignition switch
              36 - ground to main relay from DME
              37 - power in from main relay
              My M20 Frankenbuild(s)
              4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
              • der affe
                Technical
                • Dec 2005
                • 8452
                So I would be looking for + power at the "dme" (MSII) from the ignition switch to the main power at the dme, correct?
                Where are/ is the fusable links in the car?
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  Originally posted by whodwho
                  At the ECU
                  18 - steady power
                  19 - DME ground
                  This is with the key on or off? Just making sure.
                  • e30leigh
                    • Mar 2012
                    • 481
                    could be a fusable link. i think they are in the Ebox? not sure though. i know on e34's they are located in the main power coming from the battery under the rear seat. obvious that this cant be the same in an e30.
                    • whodwho
                      • Jun 2008
                      • 1547
                      That would be with the key on but there would only be ground for the FP on prime and cranking/run
                      • der affe
                        Technical
                        • Dec 2005
                        • 8452
                        At the ECU
                        18 - steady power
                        19 - DME ground
                        everything checks out except for:
                        #3 turns on the ground light on the power probe, but does not make the buzzer work
                        #36 is showing (+) and it should neg. that should be my problem
                        #37 shows (-) with the light, but does not sound the buzzer
                        so it looks like #36 and #37 are where i am going to start hunting.
                        just to check, the power goes from the DME to the main relaythen back to the DME. if the ground is bad to the main relay from the DME #36, it should be an open circuit and read as positive. because #37 is and open circuit, the relay can not open causing it to stay neg. (bear with me, these last few surgeries have kind of fucked with my thinking processes)
                        any idea where the ground for the DME is located in the car?
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          Does anyone know where the dme gets it's ground from? I have checked all the factory groumds and each of them seem to be in order.
                          • deutschman
                            • May 2008
                            • 5958
                            Also check the wires at the c101 port. If there is a short in the green wire then you could be having these problems. That should be power to your ECU.
                            • der affe
                              Technical
                              • Dec 2005
                              • 8452
                              Ok at the main relay key off:
                              #86 pos.
                              #87 (outside) ground
                              #87 (inside) weak ground
                              #30 pos
                              #85 nothing
                              With the key on
                              #86 pos
                              #87 (outside) nothing
                              #30 pos
                              #85 neg
