What's That Sound?!?!
  • NotColtonOrr
    • Jun 2011
    • 243
    The video will explain it all. Car won't start. Just keeps making a ringing noise when i try to start it up. Is it the teeth on the starter grinding with the flywheel? Just a guess. Anyway, help would be greatly appreciated. Car is a (piece of shit) 86 325e
    http://www.flickr.com/photos/7805201...in/photostream
  • dnguyen1963
    • Nov 2011
    • 2649
    Not grinding sound...it sounds like a free rotating metal disc when you start the car. You are going to have to look at the flywheel to see how bad the damage is.
    • NotColtonOrr
      • Jun 2011
      • 243
      Does this mean I will have to pull the tranny?
      • Kvasi
        • Apr 2011
        • 1122
        If its not an auto, put it in 4. and push it some centimeters.
        If auto, turn the engine a bit by hand, and try starting it.
        If it works theres some teeth missing on the flywheel.
        • NotColtonOrr
          • Jun 2011
          • 243
          It's an auto. How exactly do I turn it over by hand?
          • Hey_You
            • Nov 2009
            • 963
            Well, if your crank pulley bolt is the same as an m10, get a 32mm socket, and big ratchet, and put it on your crank pulley bolt/nut and rotate
            85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
            • NotColtonOrr
              • Jun 2011
              • 243
              So drain coolant, pull radiator, crank engine a bit, put everything back and try to start. Correct?
              • bcusitsjeff
                • Mar 2012
                • 145
                you shouldnt need to pull the radiator
                • NotColtonOrr
                  • Jun 2011
                  • 243
                  So I turned the engine by hand a bit and then started the car up. I guess that means some of the teeth on the flywheel are damaged and a new flywheel is in the near future for me. Thanks for the help guys.
