So I have an 88 IX, and I swapped in a healthy motor from another IX and did new waterpump, timing belt, pulley, blah blah blah, and it won't turn over. No solenoid click, nada. Dash lights light up, but nothing is getting to the starter, or the fuel pump, (so likely not getting to the ignition relay either). I did have a solid short occur between the positive that goes to the starter and the body the first time I reconnected the negative terminal. (cool sparks!) Is there something in line that I blew? I checked all my fuses, and am using relays from when the car was running.
I am more familiar with Toyota cars, does the e30 have a fusible links type connection that dies as a protective measure?
Do I have to enter some weird code in the computer? (just shooting in the dark here)
Not sure if this matters, but I still have to put the steering column stuff back together on the interior side (switches, plastic cover for column, etc.)
Anyway, I would be grateful for any ideas to get me started....
