Car: 88 325is
Parts replaced recently: fuel filter, fpr
Idle: around 600 when its cold out, 700-750 when warm..
As of today the car has been weird. For example, I did notice a little iffy idle this morning going to work, but in a rush I didn't examine it. When I turned off my car, the tach dropped from 1k-0 and then a second or so later heard the engine cut off. A little weird I thought.
I tried to move my car, but the car basically started and went to 500 rpm then died. I figured it was my fuel pump since the damn thing has been whining for the past 5-6 months..
I got a donor pump from Brezzi (thanks!!) and the car fired right up.. basically to 2.2k rpm, down to 1.8k rpm back and forth.. slowly died down and then would die out. When it went down to 1k it sounded like it needed a valve adjustment really bad. The fuel pump sometimes sounded like it was sucking in air, but I had a little over 1/4 tank.
Now the car idles at around 1k ish, still very stumby and such. I havent seen any gas around the pump/ground. When i hit the gas with the clutch in or neutral, it revs pretty high (3k ish) and would stumble. When in gear, I can hardly get the car to move.
I drove home 3-4 miles by holding in the clutch, revving, letting go, about every 5-10 feet. Poor Clutch!! But I cant leave the car overnight or offord a tow.
To me, it seems like the fuel pressure isnt steady enough to spray into the engine. I was touching around the c191 connector but didnt remove it. I am going to basically jump the fp relay, try removing the sock at the bottom of the fp incase its restrictive, and rechecking the c191.
Help me get to Gutenfest!! I somehow swung getting off sunday from work at the last minute, and then my 8month straight daily pulls this!
