I'm going to replace the head bolts in an effort to stop the head gasket from leaking oil. I don't have any questions, I'm just going to post my method and the results.
The motor is a m20 from an '89 e30. Currently the head leaks slightly less than 1/2 quart of oil every 500 miles or so depending on how hard I drive. The leak is between cylinders 3 and 4 on the exhaust side. Head gasket was replace by PO when the head was rebuilt, about 2 years and 10,000 mile ago.
I will be replacing the bolts one at a time in the Bently pattern using TTY (stretch) bolts.
