I cannot get my friends M20 working right. The symptoms are general lack of power, but the biggest thing is the hesitation off idle. Problem with idle is if the RPM is not up around 2500 to 3000 the engine really bogs down when the clutch is released.
Here's what I've done so far:
We did a smoke test which revealed no holes except for a slight bit of smoke coming out of the charcoal canister. It was a pretty thorough test too, as I started getting smoke out of the exhaust manifold which we knew had a leek, and was fixed that same day. I was sure this was going to be the problem, now I'm a bit lost.
Due to a clogged catalytic converter, we recently had that replaced.
The throttle position sensor appears to be working correctly.
Air filter looks good.
Spark plugs all look good.
The engine revs to redline relatively smoothly, there are no dead spots so I don't think it's the airflow sensor.
The fuel filter isn't more than a year old.
Thoughts? Could this be the O2 sensor? The O2 sensor was replaced a year ago, but since then with the cat dying and a different engine problem I suppose the O2 sensor could be dead. However there are no codes.
When my engine starts acting like this it's usually because I've sprung a big intake leak. But since that doesn't seem to be the issue here, unless the charcoal canister is not supposed to have smoke leaking out of it, I'm not sure what else it could be. Help!
