Car misses when warm.
  • Aviator
    • 616
    I have an 84 325e that runs like a top when it's cold, but gets a nasty miss when it warms up. I have all new plugs and the wires and coil wire are in great condition. I wonder if its an injector or?
    84 325e Burgundrot S52 M Tech 1.
    http://www.r3vlimited.com/board/showthread.php?t=250109
    The very first action would be to have a smoke test run and fix the leaks it reveals. Then replace the O2 sensor, ignition wires, distributor rotor & cap, and adjust the valves. If the miss is still present and compression & leak down numbers are decent have the injectors cleaned and flow tested.
