1990 325i 5 spd 400 RPM Idle + Stalling Help
  • RLGDiesel
    • Mar 2012
    • 107
    Hi all...last night I started my car up and noticed that it was struggling to run. The idle was at 400 RPM and if I revved it up it would stall or almost stall as the RPMs came back down. At first I thought it must be a problem with the ICV since my idle was slowly going up to 800-1K at stoplights earlier that day. I cleaned it with throttle body cleaner, shook it up several times, let it dry, and put it back in the car. Same symptoms. I then started looking for vacuum leaks. The air intake boot looks fine, ICV hose OK (small 2mm crack near the end that's been there for over a year), and vent tube is good. I sprayed some throttle body cleaner around the engine to hear a change in engine speed with no luck.
    Here's what I think is left...PLEASE HELP!!
    > Injector o-rings leaking
    > Intake manifold gasket leaking (esp near #6 cylinder is common apparently)
    > TPS?!?!
    Where do I start now?
    Thanks!!
  • dnguyen1963
    • Nov 2011
    • 2651
    smoke test, baby...
    • bmwguy325is
      • May 2011
      • 1263
      Sounds like a vaccum leak to me.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        Yep, have the intake smoke tested.
        • RLGDiesel
          • Mar 2012
          • 107
          Oops...no vacuum leaks found...valve cover is off under the suspicion that valves might have been tight.
          EDIT: Valves actually very loose...adjusted properly...waiting for new valve cover gasket to test if symptoms are better.
          Any more ideas?
          • RLGDiesel
            • Mar 2012
            • 107
            Problem was TPS...
            fixed a year ago but wanted to update for those with similar symptoms
