Rough idle, and stuck under 2000rpm
  • EndreM
    • Jul 2009
    • 513
    Hi guys.
    I just bought a new E30, and drove it 700kms without big problems, but ten minutes from where I live, it suddenly lost power.
    It wont go higher then 2000rpms, and if I push it, it stutters and backfires out of the intake.
    Any ideas?
    The car is a 1986 320i
    '91 E30 316i
    '97 Rover Mini 1275
    The first thing I'd check would be rail fuel pressure and delivery rate from the FPR.
    • EndreM
      • Jul 2009
      • 513
      Thanks, Ill have to check it later today.
      I changed the fuel pump, as it was really noisy, but it didnt help.
      I cant wait to drive this car!
      '91 E30 316i
      '97 Rover Mini 1275
        You still need to check rail fuel pressure.
        • EndreM
          • Jul 2009
          • 513
          Yeah, I know. Im going to steal my friends FPR tomorrow, and see if it helps.
          '91 E30 316i
          '97 Rover Mini 1275
          • EndreM
            • Jul 2009
            • 513
            Any other ideas in case its not the FPR?
            '91 E30 316i
            '97 Rover Mini 1275
              That is not a substitute for connecting a gauge to the supply line to the fuel rail. What you are contemplating is "throwing parts at the problem while hoping for a favorable outcome". Get a gauge, tee it into the supply line to the rail, and see what the rail pressure is when you try to drive the car.
              • EndreM
                • Jul 2009
                • 513
                Thanks for helping out, it was the AFM that was acting up.
                The parts I replaced desperately needed replacing anyway, but I see your point.
                '91 E30 316i
                '97 Rover Mini 1275
