Water Temp Sensor
  • Mlarsen
    • 4082
    Water Temp Sensor
    I've run into a rather interesting issue.
    The sensor that's in the car is a 3 pin deal. Which is weird because the sensor I bought is a 2 pin sensor. I'm pretty much stumped at this point. Never really heard of a 3 pin water temp sensor. It's definitely has been hacked in by the previous owner. Anybody have any insight what this sensor is from or why the fuck it's on my car.
    What car do you have?
    • Mlarsen
      • 4082
      That might be helpful, 89' 325iX.
        • 37829
        Just to make things clear, are you referring to the computer's sender, the gauge sender, or the sensor on the radiator?
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
          Okay so the car has an M20B25 engine. The ECT sensor will have two pins and the gauge sensor will usually have a single pin. The ECT and gauge sensors mount in the thermostat housing. The thermo switch (for the aux fan) in the radiator will have three pins
          • Mlarsen
            • 4082
            The ECT Sensor.
              • 37829
              Very strange, definitely have not seen that one before. Does it actually have a matching plug connected to it? Do you have a picture available?
              Grover Beach, CA
              www.BimmerHeads.com
              • Mlarsen
                • 4082
                Yeah, give me a couple minutes. My car is still hot, I just got to work.
                It does have a matching plug.
                • Mlarsen
                  • 4082
                    Does it look like the connector has been spliced in?
                    AFAIK, no three pin ECT sensor has ever been used on an M20B25 engine.
                    • paperplane94
                      • Jul 2011
                      • 420
                      yeah, that's wrong.
                      Somebody thought they owned an e31.
                      http://www.ebay.com/itm/BMW-BOSCH-0-...2661%26ps%3D54
                      • Mlarsen
                        • 4082
                        Yeah, it's been spliced in. It's weird, I have no idea why someone would do this. Let alone where or what this sensor actually is.
                        Tonight When I get off work, I'm going to put the correct plug and sensor in the car.
                        • Mlarsen
                          • 4082
                          Originally posted by paperplane94
                          yeah, that's wrong.
                          Dafuq, that's it!
                          That's weird I wonder why someone would do that.
                          • paperplane94
                            • Jul 2011
                            • 420
                            "This Mod will give the ECU more data to work with, +5 HP"
                            or something to that effect.
                              The sensor rather looks like a temperature sensor from an OBDII E36. If that is what it is it has two sensors, one for the DME and one for the gauge.
                              Open the splice up and see how many wires are spliced. An E30 harness would only two wires on the branch for the ECT sensor.
