M20b25 swapped, hard cold start, stalls warm unless icv unlugged
  • Golfer_705
    • Aug 2011
    • 59
    car 1984 325e 5speed. a 1987 325i motor harness/ecm/sensors/afm/icv/gauge cluster/etc and 3.73 LSD diff were swapped in.
    Initially the car had a consistent low rough idle around 600-650rpm. the fuel pressure regulator was tested and found faulty. it was swapped for a 2.5bar regulator until the replacement adjustable regulator came in. Idle improved and picked up to 700-800rpm but was still rough with the 2.5bar regulator. After installing the adjustable regulator at 3bar the idle dropped down to 350-500rpm and stalls constantly with the initial faulty regulator the car ran in high idle when first started (1000-1100rpm still rough) once warm it would drop to 600-650rpm. with the new regulator installed on a cold start the throttle must be held open to keep from stalling, will not idle hot, the throttle must held open for a hot restart. With the motor warm and the idle control valve still physically hooked to the intake but the electrical connector unplugged the idle raises to 900rpm and the motor runs quite smoothly. The icv has been tested, cleaned and been swapped for another known good one but it made no difference. icv does not operate when the key is initially turned on, but it starts to function (and cause problems) once the ignition is is cranked over. the icv remains operating when the engine is warm causing the motor to stall.
    the AFM, TPS & ICV have been tested and are OK. ALL other engine sensors have been replaced since the start of the rough idle problem (all were within spec or very close too but replaced from frustration) ALL of the motor seals and gaskets (head gasket also) were replaced. The distributor cap/rotor, o/p, w/p, t/b and tensioner were also replaced prior to motor installation. the timing marks are aligned. All of the vaccume hoses and intake elbow have been replaced. a smoke test was done, the intake/vaccume lines have been sprayed with carb cleaner as well as gone over with a propane bottle.
    What would cause the icv to continue to operate with the engine warm and for the icv to to operate incorrectly on a cold start??? car runs great warm with icv electrically disconnected. the round c101 (i think) connector was spliced to mate to the chassis older rectangular connector, ecm was swapped to 173 module. if anyone can think of something that may have been overlooked or a possible wiring mistake made during the swap that could cause these symptoms help would be greatly appreciated. thanks in advance to everyones help
    ***Correction*** ICV does operate with key on, couldn't be heard over background noise before
  • TurboJake
    • 3780
    The ICV operates at all engine temperatures. The fact that you stated it is not operating before cranking points towards DME to me. So it's either the DME, or the modified wiring.
    It should be buzzing with the key on the on position, without cranking.
    Leave Me Transaction Feedback
      Toss the adjustable FPR and install the 3.0bar FPR for an M20B25 engine. Then have a smoke test run and fix the intake leaks it turns up. Other possibilities exit, but intake leaks must be fixed or ruled out before investigating other possibilities.
      The engine swap included the AFM and injectors for an M20B25, right?
      • Golfer_705
        • Aug 2011
        • 59
        adjustable FPR set @ 3bar. runs great warm with ICV electrical connector disconnected, runs a little smoother warm at idle and throttle response improved with the FPR set slightly higher though (with ICV electrical connector still unplugged). With the FPR set at 2.5bar and the ICV connected it created the same consistent rough idle that the temporarily used bosch 2.5bar regulator.
        No intake leaks, all gaskets, seals, vaccume hoses, elbow replaced.
        The AFM,Throttle body, TPS, Intake, Injectors, Fuel rail, harness and ecm were all pulled with m20b25 motor
        With the ICV unplugged once warm the car runs great. ICV has been tested and swapped for another known good unit, it made no difference to cold or warm idle
        • Golfer_705
          • Aug 2011
          • 59
          the icv is buzzing with the engine cranking, once the engine is running and continues to run after the engine stalls.
          what tests are there for the DME? is there anything that could have been missed or incorrectly spliced during the motor swap?
          • Golfer_705
            • Aug 2011
            • 59
            ***update***
            with ICV disconnected from boot, electrical connector plugged in still, ignition on the icv vibrates back and forth remaining closed and makes a buzzing noise.
            ICV connected car will not idle cold. After disconnecting ICV and warming car by holding throttle slightly open till the car idled at 700rpm (idle very rough). went for an enthusiastic drive till the coolant gauge read to 1/4 (full mark above blue) and the car idled at 900rpm quite smoothly. with ICV plugged back in idle drops to 450-500 and runs very rough. as soon as the engine temp drops under 1/4 the car stalls and will not restart unless held to at least 1/2 throttle. If ICV disconnected car restarts imediatley. Coolant temp sending unit reads 260 ohms when motor is warm and 2750 ohms after sitting overnight.
            all suggestions appreciated
              The first think to do is to have a smoke test run and fix the leaks it reveals.
              • dnguyen1963
                • Nov 2011
                • 2649
                How did you test for intake leaks? I have seen many threads claiming no leaks (i.e. spraying with carb fluid), but never perform a smoke test. Please perform a smoke test if you have not done so. If there is no shop in your area that offers smoke test, you can rig one up easily (search internet) or go to www.scottykilmer.com and look up the cigar method.
                • Golfer_705
                  • Aug 2011
                  • 59
                  Intake leaks were tested for using: parts cleaner, starting fluid and a propane bottle.
                  I tried the Scotty Kilmer Cigar method smoke test today, it also reveal no leaks.
                  All of the gaskets, seals, o-rings, hoses and intake elbow were replaced under 2000kms ago
                  • BavBeater85
                    • Mar 2012
                    • 143
                    hey, dumb question, but are you positive that the afm you have is for an i motor? I did the same swap and couldnt get it to run hardly at all when warm til I figured out that the afm I thought was for the i was actually another e... I never thought to check the part numbers...she ran great cold, then as soon as she warmed up shed start misfiring and stalling like crazy, and unplugging the ICV seemed to help but wasnt the issue...put the correct afm in her and shes been running great since
                    may you rest in peace, or pieces, whichever comes first
                    • Golfer_705
                      • Aug 2011
                      • 59
                      i am fairly sure that it is the correct AFM. Bosch# 0 280 202 082 (next line) 1 286615.9 The BMW salvage yard it was purchased from had it marked as a 325i in paint pen. i looked online to cross reference all used part numbers prior to installation and all seemed okay.
                      i reconnected the ICV and have drove another 600kms since. the idle was extremely poor cold and continued to stall hot unless revved up for about the first 200kms. the last 400kms or so i still have to keep my foot on the throttle to get the car to warm up for the first cold start of the day. on a warm restart it now idles around 500-550 roughly. on a hot restart it idles at 600-650 but knocks now unless the clutch is depressed.... no knock on a cold/cool/warm restart only the rough idle
                      no thing as dumb questions, all input is appreciated, please keep posting. thanks for everyones suggestions so far
                      • paperplane94
                        • Jul 2011
                        • 420
                        My car stalled when warm due to a bad FPR.
                        It would make sense too since when you unplug the ICV, the door inside it defaults to an open position which compensates for too much fuel.
                        • Golfer_705
                          • Aug 2011
                          • 59
                          update after fuel pressure increase
                          I increased the fuel pressure today from the stock 3.0 bar (44psi) up to 53psi (3.65 bar i believe) Now on a cold/cool start/restart the idle will rise to 750rpm, drop to 500-550 for about 10 seconds then hold at 750rpm, smoother than at stock pressure but still rough. on a hot restart or once warmed up the motor idles at 600rpm fairly smoothly but continues to knock until the clutch is depressed.
                          why the continued rough start? the increase in pressure seemed to help all round with idle, it made no difference to throttle responce, mileage or driveability. what would the increase in pressure indicate with the continued rough idle on a cold/cool start/restart? how much excessive wear is increasing the pressure causing? would cause the continued knock once warm at idle until the clutch is depressed?
                          • Quinthirty
                            • Mar 2012
                            • 318
                            Fuel pump relay and connections?
                            • Golfer_705
                              • Aug 2011
                              • 59
                              relays are functioning, all electrical contacts were cleaned and inspected during the assembly
