Fuel cut out at 4500 rpm - only in 3rd?
  • kinvodA
    • Sep 2009
    • 278
    I get a hiccup when I punch the gas and to 4500, but only in 3rd gear. I searched around and noticed the common things-fuel pump, cps, injectors etc, but nothing specific to third gear. Thanks
    "Wow. We're just blowing through nap time, aren't we?"
    You don't find anything because there is nothing special about 3rd gear.
    • kinvodA
      • Sep 2009
      • 278
      I tried to re-create the problem today, nothing happened. Does it have anything to do with bouncing off the r3vlimiter, or getting close?
      • SmokeE30
        • 1730
        your rev limiter should not be near 4500 unless your in an e car, and as jim said nothing different happening at 4500 rpm in 3rd than 4500rpm in any other gear besides different wheel speed
        Shawn @ Bimmerbuddies
        Bimmerbuddies LLC
        717-388-1256
        2971a Roundtop Rd, Middletown PA 17057
        bimmerbuddiesllc@gmail.com
        • u3b3rg33k
          • Jan 2010
          • 2452
          Pretty sure motronic 1.1/1.3 doesn't care about wheel speed at all.
          Ich gehöre nicht zur Baader-Meinhof Gruppe
          Originally posted by Top Gear
          Just imagine waking up and remembering you're Mexican.
          Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
          • PNWDan
            • Feb 2011
            • 1326
            the load is larger in third at that RPM. Check your plug wires and such. I misfire due to ignition issues would cause what your describing.
            1987 Alpinweiß 325is
            Like the PNW E30 Local Crew Facebook page
