So got my new tps, and I couldnt even pop the black cover off... Bosch changed the design. Anyways.. installed it and tested it... everything there good
Car has fresh intake everything. New vac lines, new intake mani seals, new injector seals, new intake boot. I am pretty sure I have no vac leaks.
New tps has improved my idle, though it is still a tad high (900). ICV buzzes
Basically when idling if I "pop" the throttle then it revs up good (little hesitation) and on the way it down it holds 1200rpm for just a second.
I find this weird, any ideas? Car also runs cold, I believe it is an issue with my thermostat.
