Cam timing ~ stock 325i cam ~ proceedure?
  • Chuckcruzin1986
    • Jul 2009
    • 130
    Hi,
    I milled my head .050" and bought an adjustable cam gear. I want to set the cam to the "Stock" 325i setting.
    Help please
    Chuck
  • e30trooper
    • 11576
    install a stock cam then........... and put on TDC...
    • E30_fiend
      • Apr 2006
      • 7348
      Just align the adjustable cam gear to zero so there is no advance or retard then torque that down. Install the cam while the motor is at TDC, set cam to TDC and done. As long as the cam gear is centered on the cam, it will be just like the stock gear except later you can adjust it.
      Taylor
      • Chuckcruzin1986
        • Jul 2009
        • 130
        I am using a stock cam. The head is milled .050"
        Sorry I was not clear about my situation.
        Chuck
        • Chuckcruzin1986
          • Jul 2009
          • 130
          My head is milled .050"
          Taylor
          Are you saying the .050" will not change my cam setting?
          Chuck
          • slippery
            • Nov 2011
            • 375
            If you want it dead on you need to stick a degree wheel on the crank and a dial indicator on the cam itself, are you willing to buy those pieces? Otherwise you will need to take it somewhere.
            J
              If you move the head 0.010" closer to the crank center line the load side of the belt needs to be 0.010" less to retain correct cam timing. Which means the cam needs to be advanced so that the load side of the belt distance is correct.
              The cam sprocket is darn close to 4.875, which means it's circumference is 15.31". Advancing the cam to make the load path 0.010" longer is .00644 of the circumference. Multiply that by 360deg and you get 2.32deg for ever ten thou of decking.
              I don't trust adjustable cam sprockets. I've seen a couple of cases where they have shifted and the results aren't pretty, but they are expensive.
              I deck the head on a Spec E30's engine to max (the bottom of the limit dimples). To correct cam timing the index hole in the sprocket is drilled out to 1/2" and a bushing with an index hole offset by 3/16" is used to reposition the cam relative to the sprocket. Once assembled the bushing is trapped and can't come out. So there is no possibility of cam timing changing.
              The sanity check on cam timing is that both the intake and exhaust valves should be open the same amount at valve overlap. Which occurs when the piston is at TDC between the exhaust and intake strokes.
              • Chuckcruzin1986
                • Jul 2009
                • 130
                Thanks Slippery
                J
                Yes, I want to do the indicator thing. I am a machinist and do not see a problem with doing it. I see the next post has more detail and will respond to him. Thanks for you thoughts and since I am not home free, more ideas would help.
                Thanks,
                Chuck
                • Chuckcruzin1986
                  • Jul 2009
                  • 130
                  Now we are making progress
                  Thanks Jlevie
                  I would like to use an indicator on the lobes and get it right.
                  So if I understand you correctly, I will bring the engine to TDC and using an indicator turn the cam until I split the difference exactly..............
                  I hear people saying that a card comes with a performance cam so I am guessing you can do your way only with a stock cam?
                  Thanks again
                  Chuck
                    You will have to have the lobe curves as a function of crank angle for anything other than a stock cam. With a stock cam, both valves will have the same opening at valve overlap. Some other cam may be different.
                    • Chuckcruzin1986
                      • Jul 2009
                      • 130
                      Thank you again. I am off and running with this
                      :p
