M20 Idling around 1200-1500 RPM all the time
  • eek142
    • Apr 2009
    • 78
    Is my ICV bad? All of the rubber boots were replaced in the intake system a few years ago and I don't see any cracks. Occasionally, the idle drops like the car wants to stall but it bounces back up right after that.
    The error code being thrown is 1262 - Idle speed actuator.
    This problem started about 2 weeks ago. The car (1989 325iA) used to idle buttery smooth before then.
  • paperplane94
    • Jul 2011
    • 420
    Some electrical problem with the ICV.
    Other than that, did you make sure your TPS is adjusted correctly?
    • DÌEGØ
      • 690
      Vac leak?
      Driving:1990 325iS, 2007 335i :devil:
      past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
      • paperplane94
        • Jul 2011
        • 420
        Originally posted by DÌEGØ
        Vac leak?
        That too but I think the ECU would give you an A/F ratio type of code.
        Not a problem with the ICV circuit.
          That code would indicate a problem with the ICV or it's wiring.
          • DÌEGØ
            • 690
            yeah but a small vac leak that raises idle a few hundred rpm could be negligible under normal driving. if you're not having any other problems with idle Im fairly positive its a vac leak.
