To replace xternal FP w/ Tre507..Question
  • Track89
    • 153
    Did a few searches and came up short. Here is another fuel pump chump
    The external is whining on its way out, just ordered a Tre-507 inline and cant wait. That whine is driving me buzzzzzzzzzzzzz. Few questions..
    When the external is whining does that indicate that the transfer pump is also dead?
    If so, will the Tre-507 support enough fuel or does the transfer pump need to be replaced also?
    BMWfanaticVR6addict
    8 e30s - 1 e36 m3 - 3 corrado vr6s - 1 mk2 vr6 - 1 735il - 1 525i - 1 miata
    (the following have been sold, crashed, stolen or parted)
  • dnguyen1963
    • Nov 2011
    • 2648
    Whining pump can be the result of multiple things...bearing going bad, clogged in the fuel line somewhere, or fuel starvation from a weak transfer pump.
    • Track89
      • 153
      That might be an issue, the "in" hole in the filter was light brown.
      Isn't exxon gas clear when it comes out
      BMWfanaticVR6addict
      • Track89
        • 153
        Should I replace the inline first or the transfer pump? Is a whining inline a solid indication that the transfer is shot?
        BMWfanaticVR6addict
          Until you test the transfer pump there is no way to say what the whining of the high pressure pump means. If the transfer pump is dead, it can cause the high pressure pump to whine, as can a clogged filter, obstructed fuel line, or a worn high pressure pump. Test everything and replace/repair the bad parts.
