Installed a set of rebuilt m50 injectors into my car yesterday and drove 50+ km to work without issues, went to leave work later in the day and when trying to start the car was just cranking over and over but not catching. Popped the hood and found FPR o-ring on the rail was leaking heavily, I must have fucked up and damaged it while bolting it down. I picked up a new o-ring and installed it and the leak is no longer present but the car still won't start. It has a sound as if it's attempting to fire but never quite grabs. According to the Bentley manual my coil is out of spec, however I called a BMW tech friend of mine and he swears up and down that it's fine and my issue will lie elsewhere. I will check for spark from the coil and cap/rotor condition next as I totally believe my issue is ignition related (fuel on the cap/rotor and shorted maybe?)
Fuel pressure present (but unknown psi)
540 ohms on CPS
12v at ignition coil
0 ohms across primary coil terminals
6000 ohms across secondary terminals
no spark on any leads
coil plug wire 1000ohms resistance
swapped DME's for unmodified stock 173 (mine is chipped) no change
swapped fuel pump relay
swapped main DME relay
checked all fuses in fuse box
Things I have not checked
Fusible link in trunk
cap/rotor condition (about to do this, had to buy an 8mm socket as mine is missing)
injectors actuating (need a helper to crank while I listen with scope)
Is there anything else I can look at? As far as I understand it if the coil has 12v, my issue will be something between the coil and the plugs but my "tech friend" is totally convinced my issue is control related.
540 ohms on CPS
