I've got a thread going at E30tech, No luck so far so I thought I would see if anybody here has any ideas. It goes like this:
The car: 84 325e
The problem- Intermittent starting, Practically no start but it will start up every 20th time I try to start it. Seems like it will run till shut off then no start again.
What I have done and tested so far:
Fuel pump runs and is new
I changed the cap and rotor previously
Tested my Main Relay
Tested and Swapped coil with known good one
Tried Swapping ECU with a assumed good 027
Checked values at ECU- Voltage, Continuity, Resistance
Tested connectors at Main relay connection
Ran New ground wire from strut tower to valve cover gasket
Tested for Voltage at coil- 12v when ignition on
Checked for spark at plugs, - Usually no spark, some times sparks but just briefly.
Checked for spark directly from coil wire, Same= no spark or intermittent spark
I ran a jumper wire from the coil to the corresponding wire on the ECU plug with no results.
Swapped the CPS sensor with another. Tested resistance on both, around 900+- Ohms
tried swapping the obc relay box under the dash
I made a video of how the spark behaves, Turn the key it might fire just as it should, Try again and you get nothing.
Yesterday I got the car to start and actually move under its own power, I moved it to a better location in my drive way to work on it. Shut it off and it hasn't started back since.
A little more back story:
The car was my daily driver until it quit working sometime last year, I was on my way home from work and I pulled into a gas station, upon trying to start back it would not start. Came back a couple hours later, It started right up. Drove home then nothing again. The only symptoms prior to the no start condition was somewhat of a hesitation upon initial acceleration after a cold start. I did find that the fuel filter was clogged and replaced that but still nothing after doing so.
This car has been a challenge, I'd almost just sell it to avoid dealing with it any longer but I like it and hate to let it go.
The car: 84 325e
