euro m20b27's, where they different in anyway to US spec ones? specifically a 84 build date motor.
euro m20b27
Tags: None
i need to know as well, my eta was dated 5/86 and its a grey market euro1986 325e (EUR)
Grey Market
Zinno
327i Build
Zender kit
ESM 008TA
Restoration progress TBA
Originally posted by ethrtyiSsweet! day after my first final. really getting waffleswaffleswaffleswafflesed up then!! -
Early Eta's up until Sept.1985 had a compression ratio of 11:1. The blocks of these engines is stamped 27 6KA. From 9/86 the compression ratio was dropped to 10.2:1 and these engines are stamped 27 6EB.
If you mean other specs no idea lol. Im in the middle of doing a Euro piston build.Last edited by Eurotrash727; 07-31-2012, 10:55 PM.Comment
ya the super early etas were special with the 11.1 piston. finding the 11.1 pistons is crazy hard. i found a set one time but i ended up not buying them (face palm)Early Eta's up until Sept.1985 had a compression ratio of 11:1. The blocks of these engines is stamped 27 6KA. From 9/86 the compression ratio was dropped to 10.2:1 and these engines are stamped 27 6EB.
If you mean other specs no idea lol. Im in the middle of doing a Euro piston build.Comment
cool, thanks guy. The car is a 84 so I'm guessing it has the good block.Comment
im confused so if they stopped making the 11:1ratio around 9/85 and they went to the 10.2:1 ratio on 9/86 where does that leave my euro sitting at?
I just went to one of those VIN decode sites for BMW and i found this
Production date 1985-09-02
but on my door it said Manufacture date 5/86
does this mean i barely got the compression ratio 11:1?1986 325e (EUR)
Grey Market
Zinno
327i Build
Zender kit
ESM 008TA
Originally posted by ethrtyiSsweet! day after my first final. really getting waffleswaffleswaffleswafflesed up then!!Comment
