Running issues
  • Link
    • May 2012
    • 834
    Running issues
    Well today I went to do the head gasket and after removing the radiator and intake manifold. I noticed that the head gasket had in fact not been leaking and the crank case oil return was the source or half the leak, and the other half was when the previous owner replaced the intake gaskets he forgot to tighten all the bolts as most were finger tight. So new gaskets went in there, along with O rings and other necessary parts got replaced. Put it all back together.
    Then when I test drove it the car still had the same problem were between 1800 and 3500 rpm's the car would stumble as if not fuel. I took a buddy for a ride who is very motor talented and explained it to my brother, diesel tech, and they both say that it must be the fuel pump, injectors, or possibly the Dinan chip is failing.
    Thoughts?
    View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
  • SpecM
    • Oct 2005
    • 4531
    you likely may still have a vaccum leak (or leaks)
    1989 cirrisblau-metallic 325i
    • Link
      • May 2012
      • 834
      Yeah I wondered that, today it is running beautifully. So i guess wait and see what happens next time i drive it.
      • Link
        • May 2012
        • 834
        ....bump.
          Could be a bad spot in the AFM resistance trace.
          • Link
            • May 2012
            • 834
            Alright, so far she is doing good now. But we will continue to see what happens.
