Basically, when I push down on the gas pedal anywhere between 'just a little' to 'just before full throttle', it'll hesitate a bit all of the way through 2nd gear (no matter where it is on the tach). It also happens in 3rd but not quite as badly. Weird part is, there are no issues when I go full throttle (again, regardless of where it is on the tach) in any gear.
The car idles perfectly: about 800-900rpm to warm up, and then eases down to roughly 700 rpm. Of course, oil is new and clean, air filter brand new, spark plugs are solid. I haven't checked the injectors and I'd have no idea where to start with the throttle body, if that's a possibility of failure. I suppose I can't rule out any sort of modification that the previous owner may have done
The car is a 1987 325e (production date February 1987, not a SETA engine) with a 5 speed. Any insight would be great!
