little trouble starting
  • JayGotti
    • Jul 2012
    • 200
    hi so i previously bought a 87 bronzit, 2.5 straight pipe and cold air intake, and its a great machine!! BUT when i start her up it takes a while before she catches, PO says its the thermo switch on the coolant reservoir, just want to make sure what thermo switch it is so she can start normally, thanks -Jay
    • 37833
    There is no switch on the coolant reservoir. The only thing there is a level sender.
    Does the car just crank for a long time or does it cough while cranking?
    Grover Beach, California
    BimmerHeads.com
    • JayGotti
      • Jul 2012
      • 200
      it cranks for a long time then starts
      • barry
        • 1642
        Check fuel filter and bad hoses and fuel pressure, and O2 sensor, plugs, Plug wires, Dist, and Rotor, coil spark etc.
