Overheating
  • SoCalKidz
    • Jun 2011
    • 244
    Overheating
    So im about to buy this 1990 325I and its having an overheating issue. The guy has put in a new thermostat, hoses, and radiator. Its still overheating. Is there anyway to check to see if the water pump is bad or if its something else? It currtently sits in his back yard covered... So any inputs thoughs concerns? It doesnt smoke. and only leaks power steering fluid. Please help asap!!!!
  • 330i ZHP
    • 265
    head gasket may still be bad but not enough to blow smoke
    • 5Toes
      • 9836
      Test the fan clutch
      make sure the thermostat is opening
      • ak-
        • 12422
        Fan or improperly bled
        1991 325iS turbo
          • 37834
          If the thermostat and radiator and known to be good and it has been bled correctly that only leaves you with the water pump or the headgasket being the issues. Nobody can 100% diagnose the car over the internet.
          Grover Beach, California
          BimmerHeads.com
          • JCarp90
            • Feb 2011
            • 1759
            You could check for play in the water pump but I doubt that's actually the issue.
            • SoCalKidz
              • Jun 2011
              • 244
              So there is no actuall way to check? I want the car its a really clean dinan 4 door.
              • mbonanni
                • Sep 2011
                • 6236
                How much is it?
                If it is cheap enough why not buy and replace everything anyways...
                • blocke
                  • 1305
                  Was there such a thing? Or did they slap an Ebay "dinan" badge on it?
                  Parts Wanted
                  The Never-ending Resto Mod
                  • SoCalKidz
                    • Jun 2011
                    • 244
                    Well thats what i thought. I think its a stupid badge. But it has a dinan exhaust, strut bar, chip, and wing... It looks strange but good. So im picking it up and hopefully its something stupid easy.
                    • 87'moneypit
                      • Jun 2012
                      • 8
                      I saw that car on CL, looks pretty good. Thought about picking it up and fixing it so my wife can drive it. Post some pics of the car and the outcome of the overheating...hope its an easy one...
