I've got a motor out of a 1991 325i (originally an autotragic) and I'm having trouble getting the starter to engage the flywheel. I purchased an i flywheel and clutch (as the motor did not come with either) and hooked up the original starter and it sounds like the starter bendix gear would fit the flywheel, but wouldn't turn the flywheel. Took the starter off to ensure that the gear was coming out and the ground check (off the car) was fine, everything looked to be in working order.
So, the next step was to have my buddy bring over a flywheel off of an 86es. Same thing, starter kicks out the bendix gear, but doesn't engage the flywheel to rotate the motor. So, now I'm thinking, use the starter thats meant for the flywheel, so I buy an 86es starter, hook it up and same thing, bendix gear comes out, hits the flywheel, but won't engage the flywheel to rotate the motor.
Has anyone had this happen to them and if so, what was your fix and/or what am I doing wrong?
Thanks for your help.
Chris
Chris
