My car has been running hot under constant load and wont rev above 6000rpm. It pulls fine up until around 5k then struggles to get up to 6k and wont go above that. If I'm cruising around on flat ground my temps stay right around 195-200°F but if I'm on a hill they will creep up to 210-215°F. I have fault code 1222 (lambda control #1) and have been trying to resolve that as well. Would a lean condition cause it to get that hot? I tested my fuel pressure and got 36psi at idle and 42psi with vacuum line removed, pinched the return line and it shot up to 50psi+. I have replaced the following parts within the past 1000miles:
Water pump
Thermostat
Coolant temp sensor
Fan clutch
Bleed the cooling system (at least 5 times)
Fuel Filter
Fuel Pressure Regulator
Spark Plugs
Distributor cap and rotor
Tonight I'm going to test the fuel pump flow, o2 sensor, and plug wires. Any advice would be helpful at this point. Thanks
Water pump
Thermostat
Coolant temp sensor
Fan clutch
Fuel Filter
Spark Plugs
