Car was running perfect until I removed my intake manifold to get it done by Renewed Finishes.
Reinstalled a spare intake manifold, all intake gaskets. The spare manifold had a TB/TPS already mounted.
Whenever I start the car, the idle jumps up to 2k and slowly comes down, and then the motor struggles to idle. Then every few seconds, the idle jumps up and slowly returns. If I go for a drive, the car runs just fine. CEL will randomly come on/off, but mostly comes on when driving less than 10mph.
I swapped in a new TB gasket, no change. Put my TPS on the TB and no change. I've checked the vac line that goes to the intake manifold/fuel purge solenoid, vac line to ICV, Vac line that runs to the brake booster, vac line that goes to the valve cover.....
I think it is a vac leak, but there are only so many places to check....sprayed WD40 at the injectors, all around the engine and can't see to find indication of a vac leak.
Any ideas before I bring it to someone to smoke it?
