I've searched a bunch, but couldnt find much pertaining to my situation and it would be great if i could get some things cleared up.
I have a '87 325is that i am swapping a late model (1990 i believe) m20b25 into. I have an ECU with a dinan chip that came with, and was used with the m20 i am installing.
If the late model m20 and ECU are motronic 1.3, then do i need to worry about the C104 connection in the glovebox? Can i just leave it and forget about it, or do i need to do some wiring?
If my '87 was motronic 1.1 then the swap to 1.3 is all in the ECU correct? meaning that my C101 hookup on the body will be plug and play to the late model m20 C101? Do i still need to cut the wire to pin 20 on the C101 because its a ground on my cars body?
Thanks
Thanks
