Can I reuse intake gaskets?
  • txbeemertx
    • Mar 2012
    • 27
    89 325is changed injectors... Can I reuse intake gaskets?
    Thanks
  • Bimmerguy91
    • Jul 2012
    • 982
    I wouldnt. Unless it was brand new. But even still probably not
    • txbeemertx
      • Mar 2012
      • 27
      Ok I was thinking the same but wasn't 100% sure since they looked like well built gaskets. Ok thanks!
      • Bimmerguy91
        • Jul 2012
        • 982
        No problem.
        • future rs
          • Aug 2012
          • 514
          It's not recommended. I have in a tight spot but you have a higher chance of leaks.
          • TG Goose
            • Jul 2011
            • 234
            I had my intake all nice and tight with fresh gaskets on the engine stand. decided to remove intake for motor install and re-used the gaskets. done a smoke test and they dont leak. probaby only because they were only torqued for a week, but it worked out for me.
            ______________________________________
            1984 LSB 318i - Sold
            1986 325i - Motor Swapped Track Car Project
            1995 318ti - Sold
            1999 540iA - Daily Driver
            • mbonanni
              • Sep 2011
              • 6236
              I used gasket paper to make one. Doesn't leak :)
              • 5Toes
                • 9836
                put rightstuff or threebond on it and good youre good to go
                • jaywood
                  • Jul 2010
                  • 4528
                  I would replace them, they are cheap. Waiting for them in the mail is annoying though :(
                  Did you only replace the injectors? If so, you don't have to pull the intake mani. You just have to maneuver the fuel rail around a few things! If not, please disregard this ;)
