m20b27 idle problem need HELP
  • euro760
    • May 2012
    • 135
    i got a m20b27 once warmed up and im at a stop light the rpms go from idle to like 1200RPM and down and it does that but when i turn on the ac it goes back to idle and the rpms dont rise ..is it my idle control valve that i need to clean ...hope nothing big
    any help would be great thanks
  • euro760
    • May 2012
    • 135
    anyone
    • JFarhanbod
      • 2151
      This happened to my buddies eta and it ended up being the ICV and a cracked hose. That would be a good place to start.
      *shameless plug* I have an L shaped ICV for sale if ya need one
      • pantelones
        • May 2011
        • 533
        Your sentence structure is terrible. It takes more effort to try and figure out what you are saying, than to give you advice. I'll be the ass-hat that tells you to search.
        This is the opposite of what you are having trouble with, BUT it tells you what you need to check in order to diagnose the problem. Seriously, lazy people like yourself are starting to ruin the site.
        I would know too, I helped destroy a photography critique site for professional level work. I was a noob with good shots, but I had nothing that was worth sharing. The site eventually closed due to the overwhelming ratio of noobs to actual knowledgeable photographers. Live and learn fools....
        A man chooses, a slave obeys... Would you kindly?
        • Mr. Tasty
          • Jul 2011
          • 3421
          I currently have the same problem.
          2014 Alpine White 335i MSport
          (Daily Driver)
          Full Mperformance Aero
          KW V2 Coilovers
          VRSF Catless Downpipes
          • euro760
            • May 2012
            • 135
            this is why eveyrone hates forums people ask for help ...and dick like that guy come to talk them down...thanks to the guys that had nothing bad to say and helped ...
            today i cleaned the ICV and didnt idle that bad but still idle rough ..im gonna try to replace the ICV cause might be bad ...one hose had e a patch so im gonna replace it and get back to you guys to see if worked
