Before, the car was overheating badly - couldn't drive it for 15 minutes before I had to turn the heat on full blast. So I rebuilt the engine:
Started it up, and it was running great. All the bogging down and hesitation is gone. Bleed it, drove it around on the streets and highway, temperatures were below middle mark. I thought I'd solved it.
Then I thought, I'll pull over and let it idle now that it's hot. The temperature slowly crept up to halfway between mid and 3/4. Drove it and temperatures dropped. Then when I shut it off, once again the bubbling and spitting out coolant from the overflow spout.
I was told it was the headgasket that was causing that overflowing. Now it's still doing it. What else is there!!!???
- New Goetze head gasket
- Refreshed head - no cracks, is flat
- New water pump
- Engine block cleaned
- New 71 degree thermostat
