Thanks for any help - this one has me stumped.
When the ambient temperature is above 70f, my car will operate at normal temps 100% of the time. When it's colder out, the car will operate within the 1/2 to 3/4 range.
If I'm at a stop in cooler weather, the temps will creep up until I start moving again. The overheating is not dependent on vehicle speed, but engine RPM. If I simply rev the engine, the car cools down. If I'm maintaining speed in 5th on the highway, however, the car will creep to 3/4 again until I reduce my speed and drop a gear.
I have replaced the fan clutch already and the PO gutted the electric fan.
The crazy thing is that this problem is non-existent when it's warmer outside, which makes no sense. My next guess is that the accessory belt might not be tight enough, or potentially that the reservoir cap is not holding pressure. Anyone heard of anything like this before?
